PC to DE2-115 USB Communication
I'm looking for information on transferring data from a PC to DE2-115 through USB for a class project that I'm working on. Specifically, I have a grayscale image that I want to transfer to the FPGA, run some processing algorithms on the FPGA and output the processed image through the onboard VGA. I've tried working through the USB_DEVICE demonstration but there is no accompanying documentation that explains what the code does and how it is structured. What are the best resources I can use to understand FPGA communication with PC host on the DE2? Thanks!9 Replies
hi ununtrium,
i am new to this. can you help me for fpga to pc communication via usb. please tell what exactly to to do. thanks. - Altera_Forum
JTAG UART is thinked for debug, using JTAG_Atlantic is not a clean solution.. I think you have to rely on undocumented/unofficial library.
Another solution is create a TCL server: http://idlelogiclabs.com/2012/04/15/talking-to-the-de0-nano-using-the-virtual-jtag-interface/ - Altera_Forum
Thanks for the suggestions. I'll look into the FTDI solution for serial communication.
I have also found an example that does exactly what I want using the JTAG_Atlantic library but on a different FPGA. I'll look into adopting it in my project and see how it works, but if you know of any better solution I'd love to know how that works. - Altera_Forum
Forgive me - I've just re-read you first post about trying the USB Device example. I agree - there is little (no) documentation. So, if your not comfortable unpicking the example code - perhaps not.
--- Quote Start --- transferring data from a PC to DE2-115 through USB --- Quote End --- Is the "USB" a requirement? If so, then I agree with flz47655 - an external FTDI solution means you just end up with an emulated serial port on your PC to communicate with. If "USB" is not a requirement then there is a straightforward serial port on the DE2-115 board. That's as simple as they come. Cheers, Alex - Altera_Forum
I don't have a DE2 but using CY7C67200 I don't think is so easy but if you have a working example.. just use it. Maybe just using UART with CY7C67200 is simple, you have to check.
The DE2-115 board features a 'USB Device' port (J10) for connecting your board, via USB, to a PC (or other host). I don't think you need any additional boards/circuitry to accomplish what you're trying to do.
Look through the 'USB Device' example that comes with the DE2-115 board, covered in section 6.4 of the user manual (http://www.terasic.com.tw/cgi-bin/page/archive_download.pl?language=english&no=502&fid=cd9c7c1feaa2467c58c9aa4cc02131af). This talks you through the example - connecting the board to a PC, installing the relevant driver (for either a Philips ISP1362 or a Cypress CY7C67200, depending on the revision of your DE2-115 board) and running up the software that interacts with the example running on the FPGA. Providing your C/C++ program can interact with the driver, then you'll be able to push and pull data to/from the FPGA in a similar manner to the example. Cheers, Alex - Altera_Forum
It is difficult to interface JTAG UART with a custom C/C++ program. I prefer to use USB to UART module in this case.
External modules are board that you can connect to DE2, like UM232H: http://www.ftdichip.com/support/documents/datasheets/modules/ds_um232h.pdf. If you use USB to UART like UM232R http://www.ftdichip.com/support/documents/datasheets/modules/ds_um232r.pdf you can use "altera avalon uart" IP core after doing right connections with DE2. With UM232H you have to write your IP core to interface module to system. - Altera_Forum
Thanks for the suggestions. Performance isn't a concern yet, so JTAG UART will also work for me. But so far all I've been able to use it for is to receive character data from NIOS II on a terminal. I want to be able to write a C/C++ program that will transfer the bit-array of the image to the FPGA. How can I accomplish this with JTAG UART?
Also, are these external modules that you mention (UM232H and USB to UART) additional circuitry or IP Cores that can be added in Qsys? - Altera_Forum
You can use:
- JTAG UART (low performance but very simple with NIOS and Altera IP) - Gigabit Ethernet (very difficult, require understanding of timings, etc.) or for good performance (40MByte/s) you can add an external USB to FIFO module like UM232H to exploit USB 2.0 performance. This require some work. A simpler way is to add an external USB to UART external module (typ 115.200 bps/s).
