10 years agoPC to DE2-115 USB Communication
Hi, I'm looking for information on transferring data from a PC to DE2-115 through USB for a class project that I'm working on. Specifically, I have a grayscale image that I want to transfer to ...
10 years agoForgive me - I've just re-read you first post about trying the USB Device example. I agree - there is little (no) documentation. So, if your not comfortable unpicking the example code - perhaps not.
--- Quote Start --- transferring data from a PC to DE2-115 through USB --- Quote End --- Is the "USB" a requirement? If so, then I agree with flz47655 - an external FTDI solution means you just end up with an emulated serial port on your PC to communicate with. If "USB" is not a requirement then there is a straightforward serial port on the DE2-115 board. That's as simple as they come. Cheers, Alex
