8 years agoPassive serial config causing trouble with dual mode pins?
I have a Cyclone-10 LP which I am configuring with passive serial. Config works fine...chip goes to user mode, lights blink, code runs...except the Serial Flash Controller II core (version 17.1). All...
8 years agoHi Bob,
Are you using any specific Altera Cyclone 10 kit / board, or is it a custom board? Are you using a FLASH that is compatible with the SFC II controller? When you generate the SFC II controller using Qsys, it will ask you to choose the flash type with part number. Have you made selected the correct type here?
