14 years agoparallel lvds outputs
I need to drive an IR led driver at high speed. the driver has multiple channels (6) an all are paralleled in a single enable input. The driver's enable input is lvds but the input capacitance per pin could be as high as 760pF.
Pulses of 25nsec at 50ns (50% at 20MHz) are injected to the LED driver and I'm wondering if the large input capacitance will be an issue for a single FPGA output channel (cyclone III). Can be connected in parallel multiple FPGA's lvds output channels and avoid any current issue? Regards OAM4 Replies
The specifications don't seem to go well together, either a strange device or some misunderstanding. If it's a commercial available type, can you tell manufacturer and component name?
Yes, the delay is a lot.. and it will be an issue at 20Mhz. I have read the IC driver spec and they specify 760pF per input. A recommended configuration for the IC driver is to use all channels in parallel I can use a TTL instead LVDS still evaluating this so, that is why I was thinking on use paralleled outputs. Thanks for the info - Altera_Forum
LVDS outputs are dfferential current sources with 100 ohm termination at the receiver according to the standard. Capacitive load won't be a problem for the driver but of course limits the link speed.
I never heard about a "LVDS" receiver with multiple 100 pF input capacitance and can't see a reasonable purpose for it. Are you sure about the info? But definitely not a question related to Altera FPGA anyhow. - Altera_Forum
Yikes! 760pF is huge.
Quartus will take that capacitance into account for timing analysis if you set it in the board trace model parameters. A quick experiment says that 760 pF is adding 33 ns of delay for a Cyclone III. I think you should be able to use multiple outputs to increase the drive capacity. You should set timing constraints on those outputs and set their load capacitance. If you're using N outputs to drive a single input, then set the load capacitance as 760p/N for each output.
