14 years agoparallel lvds outputs
I need to drive an IR led driver at high speed. the driver has multiple channels (6) an all are paralleled in a single enable input. The driver's enable input is lvds but the input capacitance per pi...
14 years agoYikes! 760pF is huge.
Quartus will take that capacitance into account for timing analysis if you set it in the board trace model parameters. A quick experiment says that 760 pF is adding 33 ns of delay for a Cyclone III. I think you should be able to use multiple outputs to increase the drive capacity. You should set timing constraints on those outputs and set their load capacitance. If you're using N outputs to drive a single input, then set the load capacitance as 760p/N for each output.
