16 years agoParallel Flash Loader issues
Hi all, on a custom board we are using PFL (implemented in a MAX II device) to configure a single Stratix II GX device using FPP. The flash memory (S29GL064N) holds 2 firmware images, user and ...
16 years agoI was refering to V4.0 of the document, that said regarding *.rbf files:
--- Quote Start --- RBF file can be generated for the flash device as well, and you can use your own programmer to program the flash with the data from the RBF file. --- Quote End --- I'm not sure which statement is actually correct.
