16 years agoParallel Flash Loader issues
Hi all, on a custom board we are using PFL (implemented in a MAX II device) to configure a single Stratix II GX device using FPP. The flash memory (S29GL064N) holds 2 firmware images, user and ...
16 years agoIt did not work ... :(
So, what file/format should I use to program the flash without the Quartus II programmer, if HEXOUT is not compatible with PFL, and if POF format is not public ?
