binupr's avatar
binupr
2 years ago
P-tile Debug toolkit design changes
Hi there,
I am using Intel Agilex-F series development which uses P-tile. I am trying to enable P-tile Debug took kit on the Intel reference design. I am referring to Section 7.2 of P-tile Debug tool kit.
What I want to clarify is if I want o just view the P-tile status information and not configure anything to the registers, is it as simple as below steps:
1. Enable Debug Tool kit in Pcie IP configuration
2. Connect a clock to the xcvr_reconfig_clk port of the instantiation
3. Add a pin constraint to connect the xcvr_reconfig_clk to a 100 MHz clock source.
My question is do I need to drive any other signals on the xcvr_reconfig* interface to observe the DebugTool kit?
Binu
  • ZiYing_Intel's avatar
    ZiYing_Intel
    Hi Binu,
    Initial comment of the error message from the team :
    The “Conn” is a local connection which created to connect the python backend script to proceed the register read/write operation.
    Below issue suspect that the connection between frontend and backend is not successful
    Did you check back whether got any issue with the setup?
    zying
      ZiYing_Intel
      Hi Binu,
      Glad to hear that you resolved the issue by given suggestion below.
      If you feel your support experience was less than a 9 or 10,
      please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
      ZiYing_Intel
