Yes, there is only 1 destination pin.
The system has not yet been made, i hope to drive a Linear CCD sensor but i’d first like to replicate the signals sent to the CCD by programming it and measuring it using the oscilloscope. I still have to add some other components to complete that. I’ll try to apply your suggestion of a series termination at the source, when I have further info then I’ll post it.
For now I’m trying to fix an issue as my laptop crashed after which somehow doesn’t allow me to upload code to the board anymore. In the meantime, I hope my question can be answered as to how the output voltage can even reach 4.7V if I only send a 1 or a 0 from my program. Theoretically it should then only be 0-3.3V maximum with perhaps a little overshoot?
@Luckyguide wrote:
I can try to lower the amps,
I don't believe the current is particularly relevant.
@Luckyguide wrote:
but I can’t change the slew rate.
Ok
I have already answered this. If an unterminated transmission line is driven, then the reflected voltage will return and add to the source drive voltage. I recommend you look up about this. An example article:
- FvM1 year ago
do you know trace transmission line impedance? Depends on width and layer stackup, you can e.g. use popular Saturn PCB toolkit for calculation.
MAX10 LVTTL33 4mA IO standard has about 60 ohm typical output impedance, not far from lower range of expextable trace impedance. In any case you don't get much overshoot at the driving pin but larger overshoot at open trace end. Where do you measure the shown waveform?
I'm not sure if measured 4.7 V is real, it might be also caused by unsuitable probing. It's no easy to measure correct waveforms of fast FPGA output signals with passive probes.
I calculate maximal overshoot magnitude of 4.125 V at open trace end for 60 ohm pin impedance and 100 ohm trace ( 3.3*2*100/(60+100) ), but trace impedance is most likely lower.
