14 years agoOutput voltage doesn't match settings
Hello! I'm using altera cyclone II DE1 EP2C20F484C7. I've set default I/O to 1.8V, set ALL I/O bank's Vccio to 1.8V. Also I'm using expansion slot. Then I have measured voltage on expansion he...
14 years agoThank you. You are right about magic, I suppose. The board hasn't any jumpers.
--- Quote Start --- The FPGA I/O constraints must be set to match the I/O voltage (VCCIO), it does not happen the other way around. --- Quote End --- Sorry, but I don't understand =( altera.com/education/univ/materials/boards/de1/unv-de1-board.html?GSA_pos=1&WT.oss_r=1&WT.oss=de1 Reference Manual - db.tt/ptDzPht User Guide - db.tt/YE9hEsDo Shematic - altera.com/products/devkits/altera/documents/cy2_fpga_starter_board_schematic.pdf And you are right - I don't know what to look for =(
