14 years agoOutput Pin Driving Another Output Pin
Hello all, I've run into an unusual problem. I'll start off by describing my goal: I'm designing a circuit that can test for short circuits and open circuits in a wiring harness. The wiring har...
14 years agoThe schematic wdshen posted is corrrect. This is what I meant.
MOSFET or BJT doesn't make a great difference nowadays in this configuration, provided you select them correctly, in particular the specification on maximum current. --- Quote Start --- I assume I should connect the other end of the harness directly? EDIT: Also, I assume that this MOSFET should be located near the receiving end? --- Quote End --- No! The buffer must be placed at the transmitting end, just outside fpga; unless it wouldn't make sense, since you'll have the fpga pin still driving the long wire. I'd neither connect the receiving side directly to fpga, for similar reasons; I'd place a buffer here, too. Using buffered lines allows you to use a higher voltage for testing the harness, thus improving emi immunity.
