14 years agoOutput Pin Driving Another Output Pin
Hello all, I've run into an unusual problem. I'll start off by describing my goal: I'm designing a circuit that can test for short circuits and open circuits in a wiring harness. The wiring har...
14 years agoThanks a lot for the schematic. That helped clear things up. I assume I should connect the other end of the harness directly?
EDIT: Also, I assume that this MOSFET should be located near the receiving end?
