14 years agoOutput Pin Driving Another Output Pin
Hello all, I've run into an unusual problem. I'll start off by describing my goal: I'm designing a circuit that can test for short circuits and open circuits in a wiring harness. The wiring har...
14 years agoThank you very much. The wires are quite long - upto 1.5m and can be longer if they're meant for trucks. So they will indeed act as an antenna, I reckon.
What value of resistance would you recommend in this case, for a pull down? Higher or lower than 5k?
