16 years agooutput as mosfet p-ch switch
I want to use cyclone III's output as a mosfet P-ch switch. When the output will be defined low - the mosfet will be opened. When the output will be defined HI-z - the mosfet will be closed (I have pullup between G and S of the mosfet). Is it OK that when the output will be defined as HI-z, it will be short-circuited to 12V?4 Replies
A FPGA has maximum voltage and current ratings for pins, that have to be kept unconditionally.
yes. Even id the output is at Hi-Z you will still damage the device
I understand.
Just to make sure. Your answer is relevent even if te output is at HI-Z? - Altera_Forum
Maximum voltage ratings for Cyclone III and other FPGAs are specified very detailed in device handbook. You shouldn't apply I/O voltages above 3.3V (plus a small overhead). Voltages above 4.3V must be expected to damage the device immediately. You need some kind of level converter.
