16 years agooutput as mosfet p-ch switch
Hello, I want to use cyclone III's output as a mosfet P-ch switch. When the output will be defined low - the mosfet will be opened. When the output will be defined HI-z - the mosfet will b...
16 years agoMaximum voltage ratings for Cyclone III and other FPGAs are specified very detailed in device handbook. You shouldn't apply I/O voltages above 3.3V (plus a small overhead). Voltages above 4.3V must be expected to damage the device immediately. You need some kind of level converter.
