12 years agoOptimizing a design
Hello every body; I have a function that makes a transformation on th input byte, to produce an output byte, I used a look up table methode to realize this function, then I tried to realize it usu...
12 years agothe transform is simply the SubBytes transform used in the AES cipher system, is it true that the fpga nature is suitable for implementing a design using lut so it take less resources, and if I made ASIC design the carnaugh map optimization would take less resources than lut.
