11 years agoOptical Transceiver interfacing problem in stratix-V FPGA
Hello,I'm facing problem while interfacing optical transceiver of stratix-V FPGA based board with Xilinx based FPGA board.In both sides i'm using optical transceivers with sFPDP protocol at 6.25 Ghz...
11 years agoWhen you refer to cannot receive any data, is it that bit error observed or nothing at all? You can try to play around with the Stratix V PMA settings to see if can improve the situation if it is signal integrity issue.
