16 years ago
OpenCores MAC driver error mesages
Hello!
Im using a custom board with a KS8721BT chip. It have not any initialization so in the eth_ocm_phy_init() function i'm reseting it and waiting for auto negoriation to complete.
Apparently everything it's ok, I have the following log in the program:
=============== Software License Reminder ================
This software project uses an unlicensed version of the NicheStack TCP/IP
Network Stack - Nios II Edition. If you want to ship resulting object
code in your product, you must purchase a license for this software from
Altera. For information go to: "http://www.altera.com/nichestack"
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
eth_ocm_prep
Your Ethernet MAC address is 2a:52:61:75:6c:2a
Static IP Address is 192.168.1.18
prepped 1 interface, initializing...
[eth_ocm_init]
[eth_ocm_phy_init] PHY ID 0x1f 22 1619
[eth_ocm_phy_init] Found KS8721B/BT PHY
[eth_ocm_phy_init] KS8721B/BT Auto-neg capabilities: 0x1e1
[eth_ocm_phy_init] LXT972A not found!
[eth_ocm_phy_init] Marvell 88E1111 PHY not found!
[eth_ocm_phy_init] DP83848C PHY not found!
[eth_ocm_phy_init] Waiting on PHY link...OK. x=11164, PHY STATUS=786d
[eth_ocm_phy_init] Full Duplex is 1
[eth_ocm_init] Configuring MAC address 2a:52:61:75:6c:2a
Opencores MAC post-init: MODER = 0x0000a403
mctest init called
IP address of et1 : 192.168.1.18
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
But after a moment I have the next messages:
Frame dropped: too busy to receive
...(for ever!)
Any idea why this happen? I'm using a static IP, no DHCP enable in the Niche Stack.
    Hah! I wrote it, you'd think I might know what the problem is. Let me go look at the driver and see if I can refresh my memory.
    Jake
    Also, that "Frame dropped" meesage occurs while I'm not sending it anything.
