10 years agoOpencl Licensce Not Found
Sir/Madam,
I a valuating the OpenCL SDK. When I try to generate emulator version of the hello_world.cl for the default board s5_ref. I get the below error aoc: Environment checks are completed successfully aoc: Selected target board s5_ref aoc: Running OpenCL Parser "Could not acquire a valid license for the Altera SDK for OpenCL". Stack dump: 0. Program arguments: 1. <built-in>:97:1 current parser token 'typedef' Error: OpenCL parser FAILED. Refer to hello_wrld/hello_world.log for details. ---------------------------------------------------------------- When I try to generate temporary license in the self-service licensing portal I get error "No valid products found."2 Replies
- SPere43
Hello, you find a solution?
As far as I know you need a license in order to use the OpenCL SDK. You need to buy this license, I don't know anything about this procedure. But using the SDK without a license is not posible.
