OpenCL BSP for Stratix 10 GX Development Kit (H-Tile)
- 2 years ago
Hi @gustifix,
Thank you for posting in Intel community forum and hope all is well.
Note as Intel OpenCL has been depreciated, hence the support that we can provide would be the best that we can.
Unfortunately, the S10GX BSP are for the mention H-tile version.
And yes you may following the porting guide mentioned, per my understanding different between H-tile and L-tile are just the transceiver variant, hence other should be good.
Hope that clarify
Best Wishes
BB
Hi @gustifix,
Hope that clarify
Best Wishes
BB
Hi BB,
Thank you for the answer! After changing the device part number according to the guide, I had to slightly adjust the floorplan (just adding 10 to all the x coordinates in base.qsf seems sufficient) after I got some fitter errors.
Compiling the base revision works now, but timing slightly fails. I'm gonna compile it with various seeds until I get a result that meets timing requirements.
Best regards
Felix
