17 years agoOnchip Fifo AVST to AVMM and Nios
Hello all, I have run into an odd problem. I am using the SOPC 8.0 sp1 Onchip fifo. It is configured to be an 32bit AVst sink and AVMM slave out and is connected to the Nios Data Master i...
17 years agovolatile does _not_ bypass the cache. ORing bit 31 into your pointer would. If all you're doing is this sort of access, you'll never be using burst.
Cheers, - Ura
