14 years agoON or OFF chip termination for HSTL-I
Hi everyone,
I have a question, can I use on-chip termination for HSTL-I interface in ARRIA GX II family devices instead of use off-chip termination on the receive group wires (bus)? Best Regards, Roman.3 Replies
Do you see any HSTL input OCT mentioned in the Arria II hardware manual? Output driver series termination and LVDS differential input parallel termination are the only available termination options with Arria II.
Dear FvM,
thanks for answer! when I said termination, I mean parallel termination like Pull-Up to half of power supply in bank! In all application signed this only off-chip termination on Pcb, also signed that is on-chip parallel termination (VTT) available only GZ family's of ARRIA II. I did not find an information that the customer have opportunity to use on-chip (VTT) termination for HSTL-I interface standard on ARRIA GX ... Could you give me a tip(s) if I can use on-chip termination or will be better using termination on Pcb? Best Regards, Roman. - Altera_Forum
Yes, GZ series have parallel receiver termination for single ended IO standards. You didn't tell about GZ devices in your first post. But the feature isn't available for other Arria II devices that need off-chip termination.
