shubham_v_pandey's avatar
shubham_v_pandey
2 years ago
On-die capacitor and package parasitic for Cyclone V
I am looking for a model or file which has the value of on-die decoupling capacitors on power pins of the Cyclone V FPGA.
I need this value of capacitor with ESR and ESL so as to correctly model the power pins for Power Integrity analysis of the board.
Thanks in advance.
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    I also not sure if we have disclosed this information. So far, the only I can provide is the information that was included in the PDN as suggested earlier.
  • FvM's avatar
    FvM
    where did you get the idea that Cylone V has internal bypass capacitors? I'm no aware of an Intel document mentioning it. I doubt that there's room for capacitors in BGA package.
    • shubham_v_pandey's avatar
      shubham_v_pandey
      I also didn't found any information regarding this on datasheets.
      I am mostly looking for any model that can support for actual on die parasitics to mitigate for > 200MHz decoupling of power supply noise in maintaining target impedance in FDTIM analysis.
  • Hi Aqid,
    Thank you for this reply.
    This is a very good tool to provide idea of PDN.
    However, I am specifically looking for some information on decap value connected between BGA ball to die of the IC.
    a small decoupling capacitor that we place inside IC package or a parasitic effect due to this
    I am looking for IC power pin model to avoid Target impedance issues on frequencies beyond 200MHz
    AqidAyman_Altera
    Perhaps you can try to check on the Power Delivery Network (PDN) tool for Cyclone V Device. You need to download the zip file in the link below and open the spreadsheet. You can go to System_Decap tab and change the device family accordingly.
    https://www.intel.com/content/www/us/en/content-details/657243/power-delivery-network-pdn-tool-2-0-for-stratix-v-arria-v-arria-ii-gz-cyclone-v-and-cyclone-iv-devices.html?wapkw=cyclone%20v%20pdn
    Aqid
