On-Chip Memory Read/Write Issue
Okay! I think I got it! Thank you!
Do I need to mmap the second port of the sram as well? I only see a single base address for the sram.
But in the qsys I see two addresses. (Shared above)
It's a true dual port RAM so the second port would get added to the header file as well.
- greenlantern011 year ago
So I haven't built a bootloader for cyclone v.
I have used the Angstrom Linux for the DE10 Standard FPGA, programmed the fpga from the quartus software. I access the linux on the board from putty, compiled the c code and copied it to the linux and then run it from there.
Thus I never required to follow the bootloader steps and hence I am not sure if I am looking at the right header file. Can you direct me to some documentation which shows the method for creating these header files?
Thanks in advance and appreciate your patience!
Update: I was able to generate header files for my project by running the below command in the NIOS II command shell:
$sopc-create-header-files <.sopc file>
Will try to use the addresses and see if it helps!
Thanks!
