On-Chip Memory Read/Write Issue
May I know is this another question on the DMA Controller?
Sheng
Hi Sheng,
I read the documentation for the Quartus Prime 17.0 which didn't mention DMA controller compatible with Cyclone V. I compiled the design with the Quartus version 23.1 and I see some activity on signal tap from the DMA pins.
This is a question regarding the On-Chip Memory (RAM or ROM) Intel FPGA IP module. I have instantiated this module in the Qsys in the dual port mode and enabled "Initialize Memory Content". After loading this design on the FPGA I run a C code from the linux on the FPGA which tries to access the memory. Below is how the memory is connected to the HPS:
I am trying to mmap. What would be the base address for the on-chip memory FPGA ip? According to the HPS memory map, the ocram base address is 0xFFFF0000. I tried doing that but I get segmentation error.
The next I tried is 0xC0000000 since it is connected to the mai axi bus, and then add the offset address which is 0x08000000 (as shown in the qsys). I am able to read a constant value from this address. Would that be correct?
How to access the second port? Do I need to mmap it again?
