greenlantern01
2 years agoOn-Chip Memory Read/Write Issue
Hello, I am using a DE10 Standard FPGA board along with DC2390 daughter card. I am trying to use a FIFO and On-Chip Memory (RAM or ROM) module together. Capture data from the FPGA, send that data t...
ShengN_altera
2 years agoHi,
You may check these two links as well:
Sheng
greenlantern01
2 years agoHi Sheng,
Thanks for sharing these links.
I am assuming the SDRAM controller is specifically made for the SDRAM. Can the DMA be used for it? Can the DMA Controller be used for the on-chip ram?
