on chip memory does'nt work with 150 MHz on Cyclone V E development kit
hello dear Intel,
I am using Cyclone V E development kit. I set up a simple nios system(clock-pll-nios II processor- onchip memory-jtag uart) . This system runs with 50 MHz clock frequency. When i raise clock frequency to 150 MHz , system gives me an error (processor pausing and reset failed ). i can work with sdram at 150 MHz but . couldn't run with on chip memory. Does anybody know why this happens?
- EricMunYew_C_Intel
Hi, Steven
Can we close this case ?
Eric
- töz00
sorry for answer late. Yes I solved my problem. You can close this case.
Thank you for your support!
Alright, thanks Steven.
Hi, Steven
You may need to run timing analysis in Quartus, make sure there is no timing errors.
For example,
create_clock -period "150 MHz" -name {clk} {clk}
derive_pll_clocks
The timing report will tell you the max. frequency you can run, or you have to do place and route to improve timing.
Eric
- sstrell
It would be necessary to set up timing constraints and perform a timing analysis to verify where the failure is occurring.
Also, which version of the Nios II are you using: e (no license needed) or f?
#iwork4intel
