18 years agoOk I must be an idiot :P
Hi people, I am new to this so go easy on me. What I am trying to make is a block that has 3 inputs up, down, reset and one 12bit output. when i pulse up i want it to count up by 3, when I pu...
18 years agoHello Pete,
a full synchronous design as you presented would actually be the best solution. It could be however, that either no appropriate clock is present or that the up/down events are too fast for synchronous edge detection in relation to an existing clock. Special solutions are thinkable. But we don't know the timing constraints and thus it's meaningful to point out FPGA design standards. To clarify the always @ aspect of the original code example: Only one event expression from the sensitivity list can actually be an edge sensitive trigger, either positive or negative. It's the signal not appearing in a following if statement. All other events are asynchronous preloads. If you want to trigger sequential functions directly from two separate clocks, you need two separate always blocks. But than the issue is to combine the outputs from both blocks. You could e. g. have two separate counters and simply add the count values. But the sum would be undefined during events until a steady state is reached. Regards, Frank
