18 years agoOk I must be an idiot :P
Hi people, I am new to this so go easy on me. What I am trying to make is a block that has 3 inputs up, down, reset and one 12bit output. when i pulse up i want it to count up by 3, when I pu...
18 years agoHi Chris:
The problem is in the sensitivity list applied. You really want it evaluated on both rising and falling edges, and tell it to hold in the non-case. However, that being said. it is much better to do a synchronous design as follows: module updown ( input clk_i, input reset_i, input up_i, input down_i, output [11:0] counter_o ); reg [2:0] up_s; reg [2:0] down_s; reg [11:0] counter_r; wire up_rise_edge_p <= up_s[1] & ~up_s[2]; wire down_rise_edge_p <= down_s[1] & ~down_s[2]; always @(posedge clk_i) begin if (reset_i) begin counter_r <= 12'd250; up_s <= 3'b111; down_s <= 3'b111; end else begin up_s <= {up_s[1:0],up_i}; down_s <= {down_s[1:0],down_i}; if (up_rise_edge_p) begin if (down_rise_edge_p) counter_r <= counter_r; else counter_r <= counter_r + 12'd3; end else begin if (down_rise_edge_p) counter_r <= counter_r - 12'd3; else counter_r <= counter_r; end end end endmodule This takes care of async up and down signals, but glitch eaters could also be added if necessary. This also takes care of a non-count case of both up and down being pressed at the same time. Pete
