16 years agoObject file creation error during build
Im using the 9.1 version of the Nios tool and when I include one assembly source file and try to build my project, I notice the corresponding object file is not being created. Therefore I am getting ...
16 years agoFigured out the solution. Apparently the extension is case sensitive so if you rename you file to xxx.s instead of xxx.S, it should build properly.
