16 years agonStatus unconnected on cyc1
Hi, I have a design which the nStatus pin is not connected to pull up. This situation is probably the reason that i cant configure the FPGA in AS mode. But, when can configure the FPG...
16 years agoWell,
I understand that even, by chance, it is working - you are suggesting not to work with this kind of configuration (nstatus is not connected). --- Quote Start --- In addition, JTAG-only is a configuration scheme of rather limited purpose. For this reason, you won't find much users, that have tried the same. --- Quote End --- Jtag can perform FPGA programming and if it will be used for this purpose only (program FPGA via jtag each power up by a proccesor), I think it will be OK. Don't you ? (ALTERA also gave the source code and documantation for programming FPGA using JTAG and its called "jrunner") Maybe to program the FPGA with PS is better ? (but no SW to support in PS programming) thanks, Amir
