nSTATUS is sometimes asserted low during Agilex-F configuration when operating in PMBus slave mode
Hi Fakhrul,
Thanks for the review.
We have checked the above list and it is fulfilled.
Actually we have noticed that after failure there is success and so on : pass-fail-pass-fail-pass-fail...
The power is stable during the test. A failing condition occurs before ALERT goes low. It is always after a specific number of AVST Clocks; the process fails after 4130 AVST_CLK cycles.
nConfig/nStatus start ok .
I haven't read STATUS BYTE after nStatus went low because PMBus activity has not started yet. Please suggest if this can lead to something.
Itzik
Hi Itzik,
Thanks for the details. Since the failure is repeatable after a fixed 4130 AVST_CLK cycles and happens before ALERT, this points to the AVST configuration stream rather than PMBus.
Could please try the following?
Raise AVST_CLK and verify VALID/READY handling
Use a faster AVST clock (target ≥1 MHz). Keep AVST_VALID high while streaming; when AVST_READY goes low, send idle clocks with VALID=0. Capture AVST_CLK, AVST_VALID, AVST_READY, and data around the 4130‑cycle point. This fixed similar stall-at-a-fixed-count cases. https://community.altera.com/discussions/boards-and-dev-kits/agilex-3-avst-programming-fails/122255
Read SDM status immediately after nSTATUS drops
Use the AN‑936 method or Configuration Debugger to read SDM major/minor codes right after the failure. It will tell whether the drop was due to AVST stream, PMBus, or another SDM check, guiding the next fix. KDB: [community.altera.com]
Fakhrul
