Not getting the 3.3-V LVTTL and LVCOMS cyclone IV full range?
What are the characteristics of your scope probe and input?
Is it a high impedance or 50ohm termination that you have on your probe?
What is the input bandwidth of your scope channel?
A CycloneIV with LVTTL or LVTTL 3.3V output should be able to drive a 4ma to 8ma load (depending on drive selected) 48MHz (20ns period) with a 2ns to 3ns rise/fall time pretty much rail to rail.
- not_A_quitter3 years ago
You are right. I think the issue had to do with the probe bandwidth as a function of the probe multiplier. I had my probe set to x1 multiplier (no amplification no attenuation) which reduces the BW to 5Mhz according to probe the datasheet. By setting the probe to x10 i get 100Mhz BW. I did my measurements (pic attached) i got 400~500mVpp which translates to 5vpp after accounting for the probe multiplier.
