9 years agoNot able to send ethernet frame from FPGA to windows PC
Hello, I have an altera de2-115 fpga, it has two ehernet port. My aim is to send ethernet frame from my pc to fpga, then the fpga should send the same frame to another pc. i am using osinato for f...
9 years ago#include <altera_avalon_sgdma.h>
# include <altera_avalon_sgdma_descriptor.h> # include <altera_avalon_sgdma_regs.h> # include "sys/alt_stdio.h" # include "sys/alt_irq.h" # include <unistd.h> // Function Prototypes void rx_ethernet_isr (void *context); //void tx_ethernet_isr (void *context); //void tx_ethernet_isr (void *context); // Global Variables unsigned int i=0; // Create a transmit frame char=1 byte unsigned char tx_frame[1518] = { 0 }; // Create a receive frame unsigned char rx_frame[1518] = { 0 }; // Create sgdma transmit and receive devices alt_sgdma_dev * sgdma_tx_dev; alt_sgdma_dev * sgdma_rx_dev; // Allocate descriptors in the descriptor_memory (onchip memory) alt_sgdma_descriptor tx_descriptor __attribute__ (( section ( ".descriptor_memory" ))); alt_sgdma_descriptor tx_descriptor_end __attribute__ (( section ( ".descriptor_memory" ))); alt_sgdma_descriptor rx_descriptor __attribute__ (( section ( ".descriptor_memory" ))); alt_sgdma_descriptor rx_descriptor_end __attribute__ (( section ( ".descriptor_memory" ))); /******************************************************************************** * This program demonstrates use of the Ethernet in the DE2-115 board. * * It performs the following: * 1. Records input text and transmits the text via Ethernet after Enter is * pressed * 2. Displays text received via Ethernet frame on the JTAG UART ********************************************************************************/ int main(void) { // Open the sgdma transmit device sgdma_tx_dev = alt_avalon_sgdma_open ("/dev/sgdma_tx"); if (sgdma_tx_dev == NULL) { alt_printf ("Error: could not open scatter-gather dma transmit device\n"); return -1; } else alt_printf ("Opened scatter-gather dma transmit device\n"); // Open the sgdma receive device sgdma_rx_dev = alt_avalon_sgdma_open ("/dev/sgdma_rx"); if (sgdma_rx_dev == NULL) { alt_printf ("Error: could not open scatter-gather dma receive device\n"); return -1; } else alt_printf ("Opened scatter-gather dma receive device\n"); // Set interrupts for the sgdma receive device alt_avalon_sgdma_register_callback( sgdma_rx_dev, (alt_avalon_sgdma_callback) rx_ethernet_isr, 0x00000014, NULL ); // Create sgdma receive descriptor alt_avalon_sgdma_construct_stream_to_mem_desc( &rx_descriptor, &rx_descriptor_end, (alt_u32 *)rx_frame, 0, 0 ); // Set up non-blocking transfer of sgdma receive descriptor alt_avalon_sgdma_do_async_transfer( sgdma_rx_dev, &rx_descriptor ); // Triple-speed Ethernet MegaCore base address volatile int * tse = (int *) 0x00102000; // Initialize the MAC address //*(tse + 3) = 0x116E6001; //*(tse + 4) = 0x00000F02; // Specify the addresses of the PHY devices to be accessed through MDIO interface *(tse + 0x0F) = 0x10; *(tse + 0x10) = 0x11; // Write to register 20 of the PHY chip for Ethernet port 0 to set up line loopback *(tse + 0x94) = 0x4000; // Write to register 16 of the PHY chip for Ethernet port 1 to enable automatic crossover for all modes("| = OR") *(tse + 0xB0) = *(tse + 0xB0) | 0x0060; // Write to register 20 of the PHY chip for Ethernet port 2 to set up delay for input/output clk *(tse + 0xB4) = *(tse + 0xB4) | 0x0082; // Software reset the second PHY chip and wait *(tse + 0xA0) = *(tse + 0xA0) | 0x8000; while ( *(tse + 0xA0) & 0x8000 ) ; // Enable read and write transfers, gigabit Ethernet operation, and CRC forwarding *(tse + 2) = *(tse + 2) | 0x000000CB; alt_avalon_sgdma_construct_mem_to_stream_desc( &tx_descriptor, &tx_descriptor_end, (alt_u32 *)tx_frame, 60, 0, 1, 1, 0 ); // Set up non-blocking transfer of sgdma transmit descriptor alt_avalon_sgdma_do_async_transfer( sgdma_tx_dev, &tx_descriptor ); // Wait until transmit descriptor transfer is complete while (alt_avalon_sgdma_check_descriptor_status(&tx_descriptor) != 0) ; return 0; } /**************************************************************************************** * Subroutine to read incoming Ethernet frames ****************************************************************************************/ void rx_ethernet_isr (void *context) { // Wait until receive descriptor transfer is complete while (alt_avalon_sgdma_check_descriptor_status(&rx_descriptor) != 0); // Create new receive sgdma descriptor alt_avalon_sgdma_construct_stream_to_mem_desc( &rx_descriptor, &rx_descriptor_end, (alt_u32 *)rx_frame, 0, 0 ); // Set up non-blocking transfer of sgdma receive descriptor alt_avalon_sgdma_do_async_transfer( sgdma_rx_dev, &rx_descriptor ); for(i=0;i<=1518;i++) tx_frame=rx_frame; for (i=0;i<=25;i++) alt_printf("%x",rx_frame[i]); alt_printf("\n"); alt_printf("%x",rx_frame[25]); alt_printf("\n"); } This is the complete code
