12 years ago
not able to detect any instance for core < hps_sdram_p0 >
I'm trying to get into a Cyclone V based evaluation board (EBV SoCrates). While already getting LEDs to blink, on pure FPGA side, now I wanted to do a setup with QSYS. I took the "default clock", a "hard processor system" and created a "custom" component to combine it with one of my vhdl files. Another VHDL file is not in the QSYS setup. I compiled the QSYS and I integrated the resulting .qip into the project, together with the other .vhdl file.
Finally, I adjusted the toplevel VHDL file, but there seems to be something missing. After setting the LED pins and one clock pin (the same I used before). At compilation then, I get the following:
--- Quote Start ---
Info (332104): Reading SDC File: 'soc_system/synthesis/submodules/altera_reset_controller.sdc'
Info (332104): Reading SDC File: 'soc_system/synthesis/submodules/hps_sdram_p0.sdc'
Info (332151): Clock uncertainty is not calculated until you update the timing netlist.
Error: The auto-constraining script was not able to detect any instance for core < hps_sdram_p0 >
Error: Verify the following:
Error: The core < hps_sdram_p0 > is instantiated within another component (wrapper)
Error: The core is not the top-level of the project
Error: The memory interface pins are exported to the top-level of the project
--- Quote End ---
What is wrong here? What is meant by "hps_sdram_p0", I did not write a component by this name - where can I look this up?
I tried to verify the items, but I'm completely unsure. How can I check if hps_sdram_p0 is instantiated within another component?
The .qip (supposed it is meant by "core"), is definitely not the toplevel. I assume the "memory interface pins" as main cause, since I did not set anything here. But - which memory inteface pins, do I need? Where to look up what is required, in order to check its address in the processor's datasheet??!
  • PShar32's avatar
    PShar32
    hi,..
    I was suffering the same .. and I followed the steps you provided.. and when I run TCL scrip I get error like.
    Error:Error: The core < hps_sdram_p0 > is instantiated within another component (wrapper)
    Error:Error: The core is not the top-level of the project
    Error:Error: The memory interface pins are exported to the top-level of the project
    Error:Error: Alternatively, if you are no longer instantiating core < hps_sdram_p0 >,
    Error:Error: clean up any stale SDC_FILE references from the QSF/QIP files.
    Error:Info: Dumping reference pin-map file: hps_sdram_p0_all_pins.txt
    Error:Error (23031): Evaluation of Tcl script F:/<----->/synthesis/submodules/hps_sdram_p0_pin_assignments.tcl unsuccessful
    Error:Error: Quartus Prime TimeQuest Timing Analyzer was unsuccessful. 8 errors, 3 warnings.
    But when I delete the <hps_dram_p0.sdc> from /synthesis/submodules I see no error in main compiler..... !
    but it shows some error when i use nios II fast core.. like
    Error (210039): File F:/micro_pmu_structure_01/output_files/micro_pmu_daq_time_limited.sof contains one or more time-limited megafunctions that support the Intel FPGA IP Evaluation Mode feature that will not work after the hardware evaluation time expires. Refer to the Messages window for evaluation time details.
    Hi again, I think I found a solution to my problem, my fix was
    1) run "start analysis & synthesis", once to read the information, then
    2) in "Tools" -> "TCL Scripts...", run the script <my system>/synthesis/submodules/hps_sdram_p0_pin_assignments.tcl
    3) and then running the compilation
