hi,..
I was suffering the same .. and I followed the steps you provided.. and when I run TCL scrip I get error like.
Error:Error: The core < hps_sdram_p0 > is instantiated within another component (wrapper)
Error:Error: The core is not the top-level of the project
Error:Error: The memory interface pins are exported to the top-level of the project
Error:Error: Alternatively, if you are no longer instantiating core < hps_sdram_p0 >,
Error:Error: clean up any stale SDC_FILE references from the QSF/QIP files.
Error:Info: Dumping reference pin-map file: hps_sdram_p0_all_pins.txt
Error:Error (23031): Evaluation of Tcl script F:/<----->/synthesis/submodules/hps_sdram_p0_pin_assignments.tcl unsuccessful
Error:Error: Quartus Prime TimeQuest Timing Analyzer was unsuccessful. 8 errors, 3 warnings.
But when I delete the <hps_dram_p0.sdc> from /synthesis/submodules I see no error in main compiler..... !
but it shows some error when i use nios II fast core.. like
Error (210039): File F:/micro_pmu_structure_01/output_files/micro_pmu_daq_time_limited.sof contains one or more time-limited megafunctions that support the Intel FPGA IP Evaluation Mode feature that will not work after the hardware evaluation time expires. Refer to the Messages window for evaluation time details.
