Vijay_shanmugam
4 years agoNot able to convert the Agilex *.sof file to *.pof file for QSPI flash in Avalon-ST configuration
PFL II IP will configure the Agilex using Avalon-ST configuration schemes. PFL II IP connects with QSPI flash.
Here we are not able to convert the Agilex *.sof file to *.pof file for QSPI f...
YuanLi_S_Intel
4 years agohi, since you are using 2gb qspi flash. Can you try to select CFI2GB and test on it?
