Vijay_shanmugam
4 years agoNot able to convert the Agilex *.sof file to *.pof file for QSPI flash in Avalon-ST configuration
PFL II IP will configure the Agilex using Avalon-ST configuration schemes. PFL II IP connects with QSPI flash.
Here we are not able to convert the Agilex *.sof file to *.pof file for QSPI f...
Vijay_shanmugam
4 years agoI am using Avalon-st x8 configuration method, so cannot use "convert Programming Files" options. Configuration userguide suggest to use "Programming file Generation" options
