8 years agoNo logic elements although I have an output
Hello Please guide me why I don't see any logic element for the current code : LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to def...
8 years agoThank you , This is the code, the 2d image is :
TYPE Array2D IS ARRAY (0 TO 16, 0 TO 16) OF signed(9 DOWNTO 0); ENTITY AVhdl IS PORT ( clk: in std_logic; BuffD_RP1,BuffD_RP0: out vector_array); end AVhdl; Architecture behave of AVhdl is Signal Im : Array2D:=(("0010000111","0001111110","0001001101","0001011011","0001101001","0001101011","0001101001","0001100111","0001101000","0001100000","0001110011","0010000100","0010001111","0010000000","0001100000","0001000100","0000000000"), ("0010000111","0001111010","0001001010","0001011001","0001100110","0001101000","0001110010","0010000001","0001101111","0001011100","0001101001","0010000011","0001111010","0010011000","0001000111","0000010010","0000000000"), ("0001100011","0001110111","0001000110","0001010110","0001011111","0001100001","0001110100","0010011100","0010101100","0001101111","0001100011","0001101001","0001110100","0001100000","0000011001","0000110101","0000000000"), ("0001001100","0001111000","0001000101","0001011000","0001011011","0001100011","0001111000","0010011111","0010110010","0010101111","0001111000","0001010000","0010000001","0000101100","0000100100","0001111100","0000000000"), ("0001010010","0001111100","0001000101","0001100000","0001100000","0001100110","0010000101","0010011000","0010011111","0010100100","0010011111","0010100011","0010100111","0000100101","0001011111","0010001000","0000000000"), ("0001010101","0010000000","0001000100","0001100100","0001110110","0001101001","0001101100","0001011111","0001100000","0010010011","0010101001","0010011100","0001010110","0000110011","0010000110","0010000011","0000000000"), ("0001010110","0001111111","0001000100","0001011001","0001111011","0001010111","0000110001","0000101001","0001110100","0010100100","0010000101","0001010000","0000011011","0001011101","0010001101","0010000011","0000000000"), ("0001010010","0010000000","0001001000","0001011011","0001011100","0000101010","0000100001","0001101100","0001111100","0010011100","0010000010","0000101110","0000100111","0001111101","0010000100","0001111010","0000000000"), ("0001001011","0010000010","0001001110","0001010111","0000111001","0000100100","0001001000","0001111001","0001100001","0010000011","0001010001","0000110000","0001000100","0010000100","0001111100","0010000100","0000000000"), ("0000111010","0010000000","0001010011","0001000000","0000101001","0000111000","0001010000","0001101110","0010001001","0010000011","0001100101","0000110001","0001100011","0001111110","0010000110","0010110000","0000000000"), ("0000111010","0010000100","0001001010","0000111000","0001000100","0001001110","0000101101","0001100111","0001110111","0010000001","0001000001","0000110111","0001111011","0001111000","0010011111","0010111101","0000000000"), ("0000110001","0010001000","0001000001","0000111001","0001011111","0000110010","0000011101","0001001001","0001110011","0001101010","0000011100","0001000011","0001111111","0001110110","0010101110","0010110001","0000000000"), ("0001000011","0010000010","0000110110","0000110001","0001010010","0000110011","0000011010","0000111100","0001110100","0010001101","0001100000","0001000101","0001101101","0001101000","0010100001","0001001100","0000000000"), ("0001010011","0010000010","0000101101","0000100000","0001000000","0001000111","0000100100","0001010001","0001110011","0010001100","0010110010","0001101011","0001110010","0010001110","0001111110","0001000100","0000000000"), ("0001001111","0010000100","0000101100","0000011011","0000110101","0000101011","0000110010","0001100010","0001110011","0001111100","0010101001","0010001111","0001001111","0010001001","0001010100","0000111110","0000000000"), ("0001011101","0010000100","0000100111","0000101001","0000110011","0000101000","0001001111","0001101101","0001110110","0001111000","0010010101","0010011111","0001001110","0001010111","0000111110","0000110110","0000000000"), ("0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000")); signal Bufftemp,Bufftemp1:Array2D; begin ------ RP0 RP0: Process (clk) variable i,j:integer range 0 to 7:=0; variable temp2,temp1:signed(9 DOWNTO 0); begin if (clk' event and clk='1') then i:=i+1; if i>7 then i:=0; j:=j+1; if j=8 then j:=0; end if; end if; temp1:=Im(2*j,2*i)+Im(2*j,2*i+2); Bufftemp(2*j,2*i+1)<= Im(2*j,2*i+1) - 5; BuffD_RP0(4*j+i)<=Bufftemp(2*j,2*i+1); Bufftemp(2*j,2*i)<=Im(2*j,2*i)+ 5; end if; end process; ------ RP1--------- RP1: Process (clk) variable i,j:integer range 0 to 7:=0; variable Stemp,Dold,Dnew,temp2,temp1:signed(9 DOWNTO 0); begin if (clk' event and clk='1') then i:=i+1; if i>7 then i:=0; j:=j+1; end if; temp1:=Im(2*j+1,2*i)+Im(2*j+1,2*i+2); Bufftemp(2*j+1,2*i+1)<= Im(2*j+1,2*i+1) - 5; Bufftemp(2*j+1,2*i)<=Im(2*j+1,2*i)+ 5; BuffD_RP1(4*j+i)<=Bufftemp(2*j+1,2*i); end if; end process; end behave; -- As you see i either use 2i, 2j with +1 or without it. So the same index in not repeated.
