8 years agoNo logic elements although I have an output
Hello Please guide me why I don't see any logic element for the current code : LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to def...
8 years agoThe problem I got after removing for statement is that , I have a shared signal which is a 2D array. I assigned values to different cells in each process. But in compilation, Multiple constant assignent error is shown . My question is that , Isn't it possible to assign values to the same array in different processes if the places of assignment are different ?
This is the code if you may... -- In process 1 : if (clk' event and clk='1') then Bufftemp(2*j,2*i+1)<= Im(2*j,2*i+1) - 5; end if; -- In process 2 : if (clk' event and clk='1') then Bufftemp(2*j,2*i)<= Im(2*j,2*i) - 5; end if; Error : Error (10028): Can't resolve multiple constant drivers for net "Bufftemp[0][0][9]"
