8 years agoNo logic elements although I have an output
Hello Please guide me why I don't see any logic element for the current code : LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to def...
8 years agoThank you very much Tricky and FvM. I am really appreciate your instant help. I figured out a solution to read one element each clock cycle as listed as I see it best solution
Process (clk) variable i,j:integer range 0 to 7:=0; begin i:=i+1; if i=7 then i:=0; j:=j+1; end if; if (clk' event and clk='1') then Bufftemp(2*j,2*i+1)<= Im(2*j,2*i+1) - 5; Buffsig<=Bufftemp(i,j); OutResult<=Buffsig; end if; end process;
