8 years agoNo clocks defined in design / Minimal verilog only example
Hi, I've been stuck at this for two days. First of I'm very new to Altera so this is probably something very simple but I just can't figure/google this one out. I've set up a simp...
8 years agoIf your module was not the top level, and you connected the clock port to '1b1 or 1'b0, then it would be stuck at 1/0.
If this module is your top level, you've already assigned the clk port to a pin, so it will be connected correctly, (and not stuck at 1/0). The lack of outputs is the problem. The compiler sees your design does nothing useful, and removes all the logic.
