8 years agoNo clocks defined in design / Minimal verilog only example
Hi, I've been stuck at this for two days. First of I'm very new to Altera so this is probably something very simple but I just can't figure/google this one out. I've set up a simp...
8 years agocheck the warnings and ensure it hasnt removed all of your logic. This can often happen for several reasons:
- Clock not connected, or stuck at 1/0 - Reset always asserted - Input logic stuck at specific value, causing design to be optimised awa - Design having no effect on any outputs. If you have no outputs in the design that can connect to pins, then the whole design will be optimised away.
