17 years agoNiosII for uClinux
Hi all, sorry if I write in wrong section. I have designed my own NiosII cpu for a StratixII Dev. Kit. (http://www.altera.com/literature/manual/mnl_nios2_board_stratixii_2s60.pdf (http://www.altera.c...
17 years agoDid you test your hardware with a software project without using uClinux? If this works, check your kernel configuration.
I suggest you, build the minimal uClinux version for the the hardware example full_featured (\altera\90\nios2eds\examples\vhdl\niosII_stratixII_2s60_RoHS\full_featured). Then test with your hardware.
