11 years agoNiosII flash programmer elf->flash
Hi I'm looking for a "how to" get a nios2 project burned to flash, thinking that it all should end in a .pof file. Got a .sof from the OnDie example, but needs to add my modified NIOS2 project ...
11 years agoHi
Not sure i understand your question, but i followed this guideline to convert the .sof to .pof(flash) --- Quote Start --- https://cloud.altera.com/devstore/pl...10m50-dev-kit/ Look at the document link and search for the section that is called: Merging the NIOS executable into the FPGA configuration file . That will show you how to get the SW executable merged with hardware image and if stored on flash removes the requirement for a connection to a host computer. Let me know if that helps. --- Quote End ---
