17 years agoNIOSII flash downloader probelm
I use the software 8.0,quartus 8.0 and sopc 8.0,niosII 8.0. my spoc file:3c_40.sof download in quartusII then I use the NIOSII hardware run,the result ok but when I want to flash the whole por...
17 years agoI seems that your project is defined with an EPCS128. Change that setting in Quartus first and recompile your design.
But I still can't see how you are going to fit all this in an EPCS4... You can replace it with a EPCS16, they are pin-to-pin compatible.
