17 years agoNIOS2 IDE problem
Hi everybody, I have this code error when i try to run any application. --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK ...
17 years agoThis may sound like a hoaky answer but try it. I have personally experienced this several times and haven't been able to explain the cause.
1 - Close everything (Quartus, SoPC builder, and NIOS II IDE) 2 - Launch Quartus and open your project. 3 - Launch SoPC builder. 4 - Re-generate your SoPC design. 5 - Close SoPC builder (very important). 6 - Compile the project in Quartus. 7 - Launch the NIOS IDE. 8 - Make sure your system library is pointing to the correct PTF. 9 - Recompile your NIOS project and visually make sure that it is recompiling the system library. 10 - Now try it. Jake
