17 years agoNIOS2 IDE problem
Hi everybody, I have this code error when i try to run any application. --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK ...
17 years agoIt looks to me like the IDE has wrong information about where the sysid peripheral is located in the address map. Look at your SoPC builder system. Is the System ID peripheral located at 0x12021CA8? If not then:
1 - Make sure your SOF is getting into the chip. 2 - Make sure your system library has been correctly regenerated from your current SoPC builder system. It's pretty common for people to copy a project and still have their IDE project pointing at an old PTF file. Jake
