17 years agoNIOS2 IDE problem
Hi everybody, I have this code error when i try to run any application. --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK ...
17 years agoi have the same error :(
--- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x12021CA8: ID value does not match: read 0xFFFFFFFF; expected 0x79EB8C32 Timestamp value does not match: image on board is older than expected Read timestamp 0:59:59 1970/01/01; expected 15:11:28 2009/06/16 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Restarting target processor --- Quote End ---
