16 years agoNIOS II-Using FLASH programmer to download the correct procedure, but do not run ok !
Hardware system: EP2C8 + EPCS4 + SDRAM + LED + LCD
Hardware Background: Using Verilog code to write, compile, AS manner POF file to EPCS4, off electricity, the electricity, the normal functioning properly --- LED flashes Shuo, LCD graphic display properly. (Make sure the circuit is no problem about EPCS4) Software systems: NIOS II The problem: Run as Mode, LED normally flashes, LCD can also display graphics properly. Downloaded to EPCS4, closing the electric, power, LED will normally flash, But LCD no display! ing FLASH programmer download, print out a letter of interest rates is as follows: # !/bin/sh # # This file was automatically generated by the Nios II IDE Flash Programmer. # # It will be overwritten when the flash programmer options change. # cd E:/NIOSII/Study/IPM_IM_NIOS/software/IPM_IM/Debug # Creating .flash file for the FPGA configuration "$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="E:/NIOSII/Study/IPM_IM_NIOS/IPM_ IM_NIOS.sof" --output="IPM_IM_NIOS.flash" Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=IPM_I M_NIOS.opt E:/NIOSII/Study/IPM_IM_NIOS/IPM_IM_NIOS.sof IPM_IM_NIOS.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 71 megabytes Info: Processing ended: Tue Mar 09 14:07:03 2010 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:03 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert IPM_IM_NIOS.pof IPM_IM_NIOS.rpd Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 70 megabytes Info: Processing ended: Tue Mar 09 14:07:07 2010 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:04 # Programming flash with the FPGA configuration "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x01001800 --instance =0 "IPM_IM_NIOS.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK : Checksumming existing contents 00000000 : Verifying existing contents 00010000 : Verifying existing contents 00000000 : Reading existing contents 00010000 : Reading existing contents Checksummed/read 7kB in 0.1s 00000000 ( 0%): Erasing 00010000 (50%): Erasing Erased 128kB in 2.1s (60.9kB/s) 00000000 ( 0%): Programming 00010000 (50%): Programming Programmed 122KB +6KB in 3.0s (42.6KB/s) Did not attempt to verify device contents Leaving target processor paused # Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="IPM_IM_NIOS.flash" --input="IPM_ IM.elf" --output="epcs_flash_controller.flash" # Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x01001800 --instance =0 "epcs_flash_controller.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK : Checksumming existing contents 00010000 : Verifying existing contents 00020000 : Verifying existing contents 00010000 : Reading existing contents 00020000 : Reading existing contents Checksummed/read 82kB in 2.0s 00010000 ( 0%): Erasing 00020000 (50%): Erasing Erased 128kB in 2.1s (60.9kB/s) 00010000 ( 0%): Programming 00020000 (50%): Programming Programmed 47KB +81KB in 3.0s (42.6KB/s) Did not attempt to verify device contents Leaving target processor paused1 Reply
how to make it?
